Is it possible to recreate an antique radio dial face in Fusion 360?
I am in the process of restoring an Arvin Model 61 radio (roughly 1938 vintage). It has two plastic dials and they have deteriorated to the point that they are unusable. I have a high resolution scan of the dials. I've mic'd the thickness. I have a good idea what the diameter is. There is an oval shaped "notch" in the larger dial that I believe can be replicated fairly easily. My thought is that I can recreate them on a mill. I have an Othermill Pro. I'm not 100% sure that I can use it to create the dials. I thought that I could engrave the numbers and letters with a V-bit, fill the lettering in with black ink (Sharpie?) and cut out the dials, holes, etc with an end mill. The mill will accept a Fusion CAM file (whatever that's called).
Is there a way to use the scans to start the process of recreating the dials?
I have already drawn the two new hubs (for holding the dials) in Fusion 360 (first project actually). I used an 1/8" thick flange, on brass round stock, with 4 small threaded holes for each dial. Measurements lead me to believe that the flange won't cause problems but the original dial holding method was small triangle shaped pieces of metal that were hammered over the plastic at the edge of the hole.
I have not modeled them in CAM. I'm still trying to figure out how to use CAM
The following images are of the two dials in question Note that the large dial (below) has a large piece missing in the middle.
These images are of the dial hubs. They are not perfect as far as hole position on the rim goes but they are dimensionally accurate.
Small dial hub
Large Dial Hub
