Is it possible to put drawings dimensions into a table not beside the part?
Hi guys. I have made a basic matrix drawing template for a parametricly modelled table I build, with varying overall dimensions. I've discovered that there is no "generate cut list" on fusion however what im trying to find out is there a way to create a dimension in a drawing then copy paste that dimension into a table? For say a table leg ideally I could remove the description from my parts list then have three columns :length,width,thickness? Or at least copy paste the dimension of the part into the description row beside the part name which would also update when the model changed. I have attached a picture of one of the drawing pages, as you can see a cutting dimension's list in the description row would be very easy to read and use especially when the parametrics are changed the cutting list I created would auto change as well!
Can this be done?
Thanks in advance
jodom4
Hey loganrmay,
I think this plug-in will do the trick: https://www.youtube.com/watch?v=dwWDpQSrz7o
Jonathan Odom
Community Manager + Content Creator
Oregon, USA
Become an Autodesk Fusion Insider
