is it possible to move a form body from one component to another?
Johnc911
Johnc911
I accidentally created a complex form body in the wrong component (the wrong one was activve). Is there a way to move the form body into the other component? Whatever I've tried has not worked (copy/paste, drag anddrop).
I'm want to move the fully editable form body (purple state), not just the final brep version of it.
Thank you
Johnc911
i figured it out. I had to export the control frame and then import that obj mesh into the component and then convert quad mesh to tsplines.
if you have a better way let me know
Thank you
laughingcreek
while editing the form body, select the body and "copy" it.
exit from that and go to the new component, edit the new form instance, and "paste".
