Hi everyone im still new at fusion360 and learning the workflows, im used in modelling with a non parametric 3d modelling programs where I can modify faces,verteces in any way I could. I have a simple bracket model where I want the end to be fan or chisel like at the end either by expanding the face or something else which I dont have any idea how to do on Fusion360 or maybe it needs a different approach. Looking forward for your suggestions and help would be much appreciated thank you.
Solved by Bunga777. Go to Solution.
This may not be the purpose of your question, but if you want to make the changes shown in the figure with the shape of this part, it would be easier to fabricate it from such a sketch.
We have also pasted the data for your reference.
Click here to view the video.
https://knowledge.autodesk.com/ja/community/screencast/48e8234c-8675-4480-9c76-32a2133fab87
Not to be encouraged but as a quick and dirty workaround, you can Move Face Rotate and choose the Axis. Most times Fusion 360 will play nicely.
I realized it is perpendicular and I was sketching it along 45degress which makes it more difficult and inefficient, your approach was simple and amazing thank you so much for the solution.
