Is it possible to emboss a shape onto a curved surface such as a half sphere?
gak19043
gak19043
Hi. I am trying to emboss (onto a half sphere) the stitches you see on a baseball. My half sphere is only .875" in diameter.
How do I do this? Is there a tutorial I can view to learn how to do this?
What do I need to do, when creating the stitches, in preparation for them being embossed onto the surface? Are the stitches a separate file (what type?) that is then imported onto the sphere? And somehow laid onto the surface?
Thanks to all in advance for your help.
Warmingup1953
A real baseball of course is stitched....are you simply looking to create a simpler visual version you can 3D print?
jhackney1972
Creating the correct seam, to be used as a path, is the first job.  I did not spend much time on creating a realistic stitch but you can get the idea.  I do not know of any tutorials but you can take this model apart for information.  Model is attached.
John Hackney, Retired
gak19043
Thanks John, I'll check your model out.
Much appreciated.
gak19043
Yes a simpler version, not an exact realistic effect. But embossed, meaning these stitches will be slightly raised on the surface of the half sphere so I can delicately paint them.
