Is Fusion 360 Really intended for engineers?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have been using CAD software for over 20 years like SolidWorks, Creo (Pro/E), Unigraphics etc.
as an engineer i am seriously struggling understanding Fusion 360 demographics.
i like to try new technologies but i am struggling with basic simple functions in Fusion360.
my question: is Fusion eventually will replace Inventor and will have all the features of Inventor, which are similar to SolidWorks features? or it will always be a lower end software for casual users who do not require all the real engineering features?
i love using the CAM module for Fusion, it is by far the best i have seen, the modeling part is just inferior to almost all existing CAD packages on the market, maybe except ONSHAPE
the topic is so long to cover here but here are my comments:
- joint as designed for fusion are OK for simple symmetric parts, it would be nice if lower level mating is considered also, for instance i wanted to machine a cylindrical part in a V shaped jaw vertically, i simply wanted a tangent relationship which is not available ( too many steps to get it to work currently)
- for some reason when i import a part into an assembly, the original plane and coordinate system are locked in one place on the screen even though the part was moved around, they are in the right location when the part is opened alone
- i couldn't create a diameter dimension in a revolve feature, everything has to be designed in a radius environment, this should be a no brainer
- i cant create relationships to any existing datum plane, it only supports the origin only!
- too many steps to rotate a component in 3D
- capture position is so frustrating to deal with, it should be optional not the default
this is a small list of things i still believe should be addressed.
i am really here because i like Fusion360 to be a successful software, i think it is a good platform and priced right.
my biggest issues with Solidworks after using it for 18 years is the lack of attention to its increasing instability.
my previous Autodesk encounter was AutoCad which is bullet proof regarding its stability.
please don't look at my comments as negative ones but more of constructive criticism, i believe competition creates better product for everyone and would like other companies to be a real competitor to Solidworks.
thanks,
