iParts in Fusion 360
DerryAutoDesk
DerryAutoDesk
Hi Everyone,
Does anyone know if there is a way to create iParts (from Inventor) in Fusion 360?  If any of you have Creo experience, family tables.
Basically, I am making a square tubing frame.  All the parts are the same width and thickness but they are different lengths.  I am trying to figure out if it can be done easily in Fusion without creating all new bodies / components.
David
TrippyLighting
Nope!
In other CAD systems (Solid Works, Alibre Design, ZW3D, OnShape and others) this is called :"Configurations" and is not available in Fusion 360.
I_Forge_KC
There isn't a good way to incorporate the "family members" into a single file (automatically anyway). What you can do, though, is auto-generate the files themselves and then use them as a library.
Check out:
https://github.com/hanskellner/Fusion360ParaParam
The export to Fusion function here will save a boatload of F3D files that you can bulk upload into a folder and then use it as a library.
K. Cornett
Generative Design Consultant / Trainer
DerryAutoDesk
Thank you both.  I was hoping there was a way because it is a very simple process.
Thanks for the suggestions.
