Hey guys I am stuck on this problem I am trying to figure out how to do a revers mirror, I am working on the Black Arrow from The hobbit moves for a buddy and I was going to utilize Fusion 360's mirror to do the twist and manipulation the two bars around each other. It worked in making the initial curves. But now I need to inverse the work flow on one. I can do it manual. Bit of a pain but possible. I am in the sculpt menu I attached a image of what i am working on.
Any help would be nice. I tried looking it up, but all I are normal mirror instructions.
Thank you for your help.
Hi @Anonymous,
Thanks for your post,
I have checked you attached PNG file, in that you want to mirror but its inverted which not possible by using our current mirror operation.
But instead of that If you use Pattern or Copy-Pate operation to inverse the workflow on one.
Please check attached screen cast where I shown the workflow by using the pattern and copy-past,
Let me know if this does not resolve your issue.
Sagar
