Invert body/cutout
Invert body/cutout
david.oldridge
Invert body/cutout
david.oldridge
Sorry if this is a dumb question. I'm quite knew to CAD  and Fusion 360, but until now i have been able to learn a remarkable amount from online tutorials and resources. However, I am stuck on something I have wanted to do on several projects, but haven't been able to find any pointers - something for which I would imagine there might be a fairly simple function that I've missed..... That is how i can invert the geometry of a cutout to form a matching solid body?
I realise that in a simple example of a box with a hole in it, I can project the circumference of the hole, offset for clearance and extrude the plug.
However, in an example of say a Phillips Screw Head, with more complex 3D geometry (and for which I have a step file). How can I easily create the the equivalent of a Phillips driver bit to mate with the screw head cutout without having to rely on accurately measuring every element of the geometry and sketching it from scratch? In theory I can use different levels of projected geometry and use lofts, but I feel there is still room for minor error, and their might be a simpler method I haven't spotted..
davebYYPCU
Combine Cut the bolt from a plug.
Might help....
david.oldridge
Might help....
No  "might help" about it. It very definitely helped. Thank you so much.
I had pretty much achieved the aim with sketch projections and loft, but I kinda figured there must be an almost one-click accurate solution.
And what is more it translates and inverts the convex top of the bolt head as well. Another step in my Fusion education which I wish I had reached out for previously.
Thanks again.
