Intersection of a patterned object with a sketch [bug]
roambotics_scott
Advisor Advisor
roambotics_scott
1) create component
2) create circular pattern of component
3) create a sketch that has a nonzero intersection with one of the patterned components
4) intersect the patterned component with the sketch
expected result: curves from intersection are added to sketch in the patterned object's location
actual result: curves from intersection appears at the intersection of the sketch and the original component
roambotics_scott
Well this is odd - if I try the above as described it actually works but if I do it in my actual project, it just puts the intersection at the original location.. perhaps it's because I inserted an external design ?
roambotics_scott
Nope - even that doesn't reproduce the bug 😕
kb9ydn
FWIW, I'm finding patterning to be a bit flakey.  The other day I tried to do a one dimensional linear pattern and for some reason always ended up with a 2D pattern, even though the preview showed only 1D.  I can't seem to reproduce it though.
C|
