Intersection curve
Intersection curve
Message 1 of 10
Intersection curve
Hi, I am a long time solidworks user and I'm branching out and trying new things.  In solidworks there is a command that can make a 3d sketch of the intersection of two surfaces.  It is very simple and I use it for many many things.  I am having a very difficult time finding a similar solution in fusion360.  Please see my attached image, I am trying to make a 3d sketch that follows the intersection of these two surfaces so I can make a swept feature along the 3d path.
Thanks for your help.
Replies (9)
Message 2 of 10
SaeedHamza
Please check this screen cast
kind regards, Saeed
Saeed Hamza
Message 3 of 10
davebYYPCU
Create 3d sketch, (Under Preferences, has to be enabled)
In the Sketch Pallette, tick, 3d sketch
then Sketch > Project > Inersection Curve,
should get you underway....
Message 4 of 10
I hadn't considered using the edge of a split surface as the path.  Thanks.
Message 5 of 10
I certainly tried that a few times but it wast to have a plane to put the sketch onto.  Even though I have 3D sketch enabled.  Maybe I am just using the command wrong.  Either way, splitting the surface and using its edge as the path gets me to the solution and seems like the easiest solution, thanks.
Message 6 of 10
SaeedHamza
Hi Eric,
Please check my screencast, it's attached to my previous post.
Thanks and kind regards, Saeed
Saeed Hamza
Message 7 of 10
davebYYPCU
Sorry, Yes your right, it does require a plane to attach to, but can be any plane, does not have any other relevance to me / us.
Fusion needs it as a "ground plane" to measure from, internally. ( My logic, may not be fact)
I can't see @SaeedHamza videos on this machine, but I agree with and use that option as well,
Sketch project method works without any body/s to refer to.
Message 8 of 10
SaeedHamza
Here is this one, check it out please 🙂
Kind regards, Saeed
Saeed Hamza
Message 9 of 10
SaeedHamza
Kind regards, Saeed
Saeed Hamza
Message 10 of 10
davebYYPCU
Thank you for this type of movie, yes I can see this one, ( I noticed you had already changed over )
A comment,
you don't need to make the cutting tool as a surface, the sketch will work, just fine,
You should not delete the split from history, it makes 2 yellow icons in the timeline, but you can combine the two half bodies after the sweep.
Intersect curve does not cut the body.
Thanks...
