internal chamfer
internal chamfer
internal chamfer
hi, i'm new to modelling in fusion360. I'm trying to do an internal chamfer on an edge...... sounds simple enough, but i can't find a way to achieve it!!
I've found chamfer, and fillet, but they're both doing external shapes.... i just want to put a negative value into the chamfer command so it's an internal radius rather than external.....
Hopefully i'm missing something obvious!!Screen Shot 2016-11-08 at 13.07.56.png
HughesTooling
You're not explaining very well, I'm not sure how you can have a negative chamfer. If you want a reverse fillet try Pipe set to cut.
To get something like this.
Mark
Mark Hughes
Owner, Hughes Tooling
thankyou.
I must have explained it well enough, you answered it perfectly!!
HughesTooling
Thanks, My ESP powers must be improving.Smiley Wink
Mark
Mark Hughes
kshea9RNL8
Well, If that's the case then tell me how to correct CAM problems I'm having this morning Smiley LOL
