Inserting multiple sheet metal components into one sheet of drawing
How to insert multiple sheet metal components into one sheet of drawing. I am looking to include the flat pattern of three designs and multiple views of the design (non-flat pattern).
Multiple views (non-flat pattern) - side, front and isometric views.
I'm looking to achieve a similar drawing shown in the picture below however, I'd like to have 2 more sheet metal components in the same sheet of the drawing.
jhackney1972
Here you go.  What you want to do is add all three components to a single model, assembly, then select each one in turn and place the two views on the same drawing and same sheet.
John Hackney, Retired
jhackney1972
I should have indicated the same drawing "untitled" and the same sheet "sheet 1".
