Message 1 of 21
How do I created a rolled, sheet metal cone with an overlapped joint?
I want to make a sheet metal cone with a small overlap so that it can be glued together. I don't have any screenshots or reference photos, so I'll try to explain.
Let's say that I want to make a sheet metal cone in the sheet metal environment that is open on either side. The top is 25 mm across and the bottom is 50 mm across. The metal continues in a smooth curve from beginning to end, so the joint is not raised before overlapping. Almost like a spiral. This joint would overlap the beginning by 3mm. Then a flat pattern can be made.
