Inserting a decal in the Rendering mode.
jschiedegger
jschiedegger
New to Fusion 360... I am wanting to insert a jpg file into a top level assembly while in Render.  The dialog box opens with the file from my computer and my only option is to select a face but when I mouse over the surface of a component, I'm not getting a face to pick, only bodies.  What am I doing wrong?
Drewpan
It is probably easier to insert the decal in the original model and then select it as a part you want rendered when
you swap to the Rendering tab. There is an Fusion Tutorial about a "Box Cutter" that shows you how this works in
the Self Paced Learning.
Cheers
Andrew
mufuo
It would be easier to help if you could share the image you want to add and the part you want to render here.
Mustafa Furkan Özel
Project - R&D Manager
LinkedIn
