Inserted component can't be moved- new issue!?
patmat2350
patmat2350
I've looked here but not found this same issue...I did see it on Reddit, but with no clear solution.
This never happened before, now happens 100% of the time for me.
1. Create Component 1.
2. Create Component 2 (external, in the same project).
3. Insert 2 into 1. At time of initial insertion, I can position #2.
4. After accepting the position, #2 is now locked. Can't be moved directly, can't be moved via a Joint definition. See the image:
Help! I'm at a loss.
Edit: Added this simple example file.
jhackney1972
Just a guess, do you have Component Drag checked?
John Hackney, Retired
davebYYPCU
There is a new Preference setting,
Ground / Pin / Anchor to Parent.  Set on as default,
Turn it off, to revert to previous workflows.
Might help….
jhackney1972
You have been caught by the new "Ground to Parent" feature.  Right click on the component and remove it.
patmat2350
Oy, WHY would they do that??? And not make it more obvious? I skim the new updates, but never saw this.
But that fixed it, many thanks.
jhackney1972
You can read about it's intended uses here.
davebYYPCU
Musta been more than 50% of feedback asking for Ground on Insert, silent majority don’t give feedback.
