- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've looked here but not found this same issue...I did see it on Reddit, but with no clear solution.
This never happened before, now happens 100% of the time for me.
1. Create Component 1.
2. Create Component 2 (external, in the same project).
3. Insert 2 into 1. At time of initial insertion, I can position #2.
4. After accepting the position, #2 is now locked. Can't be moved directly, can't be moved via a Joint definition. See the image:
Help! I'm at a loss.
Edit: Added this simple example file.
