Insert fastner
Insert fastner
yarnewillems
Message 1 of 8
Insert fastner
yarnewillems
Can someone explain to me why I can't select a screw or something like that in this? I don't understand why it doesn't want to work, and on YouTube, everyone seems to be able to place a screw into a hole, but I can't.https://a360.co/4jHfkxr
Replies (7)
Message 2 of 8
jhackney1972
You hole has a diameter of 632.456mm.  Fusion does not have any fasteners in it's library for this size hole.  Make you hole a reasonable size and it works just fine.
John Hackney, Retired
Message 3 of 8
yarnewillems
i changed it to diamter 5 and it still doesnt work:/
Message 4 of 8
yarnewillems
i dont know why or what im doing wrong
Message 5 of 8
jhackney1972
Boy, talk about extremes.  From Huge to Tiny.  The video will show how to place a Socket Head Cap Screw in the hole.  I broke the external link on the fastener and attached the model.
Please stop writing Private Messages, I will answer here on the Forum.
(view in My Videos)
Message 6 of 8
yarnewillems
If I have a model in which I need to make rivets, then I need holes of 5 mm  so this is just standard in real life.
Message 7 of 8
yarnewillems
I have another model with more than 100 holes with a diameter of 5 mm, so it would be quite convenient if the "Insert Fastener" function works.
Message 8 of 8
Roman_Vesely
Hi Willems,
 unfortunately, in model from your link above https://a360.co/4jHfkxr  is only extruded sketch (without any hole or anything else). I don't know what isn't working for you. Could you share steps to reproduce or video ?
Regards
 Roman
Roman Vesely
Inventor - Principal QA Engineer
