I created a model of a workbench using parameters for all dimensions and a detailed drawing for it with 8 sheets. I then decided to convert it to a configured model so I could adjust the size of the bench and see the changes . I realize that a drawing can only have one configuration (as I understand it anyway) . When I update the model for the original configuration that the drawing was created from, the "drawn date" is not updating in the title block of the drawing for that configuration. Other attributes like drawing name and the dimensions are updating correctly, just the date that is stuck on the date I converted it to a configured design even though I have made several changes to the design over several days. Anyone know how to fix this behavior?
I should also mention that I created a new dummy design from the same configuration that the drawing that has the title block problem, and it has the current revision date for the "drawn date" attribute so this tells me that the model has the correct date associated with it.
