insert edge is not inserted
vladiksduh
Message 1 of 10
vladiksduh
Hey! Maybe I searched badly on the forum, but did not find a similar question. The situation is as follows.
Add an edge to the body so that you can continue modeling the surface. And then there is a problem.
The slider does not want to move (down in this example). What is the reason for this?
Replies (9)
Message 2 of 10
g-andresen
Please share the file and name the place to insert
File > export > save as f3d on local device  > attach it to the next post.
günther
Message 3 of 10
vladiksduh
 OK. No problem
Message 4 of 10
TrippyLighting
The reason is that you have an N-Gon there, which does not allow FUiosn 360 to determine proper edge flow. That only works well with quads.
Message 5 of 10
vladiksduh
That is, it is impossible to decide. Since Fusion 360 does not have this functionality?
Message 6 of 10
TrippyLighting
Of course, it does. It's called "Insert Point". Not particularly intuitive naming 😉
Message 7 of 10
vladiksduh
You helped me of course to understand the reason. Thank you very much!
But I deliberately deleted it to make the model better.
[video]
There is a junction in the lines (cross-cutting) and it strongly distorts the surface.
Message 8 of 10
vladiksduh
I just wanted to get rid of the edges that distort the surface.
Message 9 of 10
vladiksduh
Thanks again, everything turned out as I wanted!)
All the best to you, goodness to you and health
Message 10 of 10
TrippyLighting
I am glad it worked out!
