I was really excited when I first saw the derive function, but now it seems that it too will not provide an answer to my problem(which I feel is a rather normal function to need and rather big negative to using fusion 360).
As a simple example of my problem, lets say that I want to build a drawer with a cutout for a lock in the face? I set up the parameters for the drawer so the parts are parametric. Giving a parameter for the drawer opening width, depth, and height. I use those in functions to create parameters for other aspects of the individual parts such as, Drawer Front width, Drawer bottom length, etc.
I would like to make an individual file of the lock and insert it into the drawer assembly file as a linked component and use that to create the cutout for the lock centered in the drawer front. Such that if the shape of the lock ever changes, the cutout will change too in all the files it is used in and remain in the position I set in the drawing(lets say the location is specific, such as 10" from the left edge of the drawer and 2" down from the top edge of the drawer front).
The only parameters that will really change from project to project are the opening width, depth, and height, so I make those parameters favorites.
I would like to be able to put the completed assembly into new designs and be able to change only the favorite(or certain) parameters I selected which are opening width, depth, and height and have it change the parts accordingly while maintaining the lock position and link to the lock component in case it changes in the future. The only way I know to be able to currently do this and maintain a link back to the original lock component is to make a copy of the completed assembly, modify the favorite parameters and then save the copy as the specific sized drawer(which will leave me with lots and lots of individually saved copies) and insert it into new projects, or create one master start file with every individual component and sub assembly that I may possibly need and work backwards deleting or hiding the unnecessary ones. The latter solution leaving me with a HUGE and confusing list of parameters(side note....it would be SO nice to be able to sort parameters into named groups!!!!).
Am I missing a workflow that would let me modify the size of a sub assembly to fit a design, but still allow component changes to propagate??
The new derive feature is especially frustrating because it shows the parameters and functionality I need and have been waiting for right in front of me, BUT IT WON'T LET ME CLICK ON THEM TO CHANGE THEM!!!!
Please help!....I can't be the only one pulling their hair out over this!?!?!
