Insert a tspline face without specifying plane
Hi, I am referring to an action similar to the one in the tutorial
https://help.autodesk.com/view/fusion360/ENU/courses/AP-CONTROL-AND-REFINE
When I try to make a face, it asks me the plane on which to do it. But being in 3d space and needing to do it a lot of times to full the model, I don't understand how to add faced without specifying such plane.
jeff_strater
yes, you always need to specify a plane for a T-Spline Face command.  This gives the point a place to land if you do not snap to existing vertices.  If you only snap to existing vertices, the plane is effectively ignored.
Jeff Strater
Engineering Director
