Input for sketch object measures randomly failing?
Hey, facing an incredibly annoying issue that's only just now started happening:
I can only enter dimensions of sketch objects sometimes, other times the input field doesn't highlight in blue and pressing the tab-key isn't doing anything to let me access it.
Screen Shot 2017-02-07 at 11.05.07.pngScreen Shot 2017-02-07 at 10.54.29.png
Often it seems the first sketch object "in a while" allows me to enter a value, then subsequent objects I'm stuck to using the mouse pointer.
Happens across most tools (shapes).
Sometimes closing the sketch, changing sketch tool allows me to enter a value again on a new sketch object – sometimes that doesn't even work. Closing Fusion between sketch objects seems to work, but also annoying solution. Tried disabling snap-to-grid, didn't work.
How do I make it blue again? 🙂 Beginner so might have got something basic wrong.
jeff_strater
Hi @Anonymous,
That sounds like a bug, certainly.   If you could possibly record a screencast of the behavior you are seeing, it would help us to investigate it.
Jeff
Jeff Strater
Engineering Director
jeff_strater
Thanks for the video, @Anonymous, I will log that bug.  It seems you are on a Mac, so perhaps this is a Mac-specific bug.  It is certainly supposed to be highlighting the value even when dragging a circle.
Jeff
Jeff Strater
