Inline Addition of Parameters
benM4QF2
benM4QF2
Community Visitor
Community Visitor
This is either a feature request or a request for help accomplishing this process.
In Fusion360, while sketching and adding dimensions. It would be more efficient if I could add a parameter by assigning the dimension to be "Max_Width = 180mm". Then the Parameter would be created and if I need to use that parameter in the future or change it, I can go to the Parameter section and modify as needed.
jhackney1972
You can do this anytime you desire.  I show this is the silent video below.  The only thing you need to keep in mind it that Model Parameters are not included in the Parameter Export function.  Other than that, they can be used like other parameters as desired.
John Hackney, Retired
benM4QF2
Community Visitor
Community Visitor
John-
That's awesome. Thank you for taking the time to demonstrated. I had tried this and must have put a space where it didn't want to be. I followed your guide and it worked great.
Thanks again!
