Message 1 of 15
- Mute
- Permalink
- Report
Hi all!
I want to create something similar to my sketch below, an irregular box that looks inflated (making the sides slightly convex). The first steps seem quite straight forward; Sketching the outlines of the box using spline in a 3D sketch and adding points that will be the second profile when using loft to create a convex surface. The first loft works but not the second, the splines doesn't create a profile. It seems like the problem is that the curves move through different planes. Is there any way around this?
Preferably by working the solid mode rather than surface mode:)
Also, is there a command to move a point in the center of an irregular profile?
Many thanks,
Sofia
