Inference lines stop working at construction line
smallfavor
smallfavor
This may be a bug - but if you watch the vid you'll see the turquoise enference line stop working at the point it encounters a construction line.  Construction lines in F360 are rather lame.
http://autode.sk/2ieXKpM
had to paste in the link as none of my screencast are showing up in the insert option.  Hope the site isn't going south again.
jeff_strater
As usual, it would be good to have the specific design to test with.  But, I can guarantee with 100% certainty that it has nothing to do with being a construction line.  I've seen the code.  I tried to reproduce this with a simpler design and I can see something of it in the simpler design:
You will notice, as the coincident inference (the "X") appears, we sometimes lose the alignment (dotted line) inference.  I kind of understand why that may be, because those inferences operate on a "removing degrees of freedom" principle.  As each inference is added, it removes one or more degrees of freedom.  And this is kind of a tricky area:  It's easy, when adding one inference, that others might get dropped.  It's still a bug, of course, and with the design, I'm sure that we can investigate it to find the root cause.
Jeff
Jeff Strater
Engineering Director
smallfavor
Here ya go.
The application is running very slowly today and not responsive.  I'm wondering if there's some local cache that's causing this, but I've cleared all with an application called cocktail and restarted and I'm still getting poor performance.  Any notion why?
