Individual can render, consolidated cannot render
5 REPLIES 5
jctfjcwy
323 Views, 5 Replies
I am doing a design which consist of several buildings. In order to keep the file quicker, I design the buildings in different files. And each of the file's cloud rendering are running fine, without problem.
However, after I have imported the buildings individual files to a consolidated file in order to create a street, and the local rendering keep disappearing and the cloud rendering always not able to do with showing "Your rendering could not be rendered"
May I know where the problem is? how can I fix it?
Tags (1)
Labels (1)
5 REPLIES 5
Haad_Ali
in reply to: jctfjcwy
The only way to have the quick renders you must have powerful system, The more components you have the more focus fusion has to make on each and individual component. And, if you don't have powerful system in backup then its fails every time and even give bad results if luckily done. I have the same problem like yours i just change my system and now its working fins. Thats is the only solution for getting better rendering results. I hope it helps.
jctfjcwy
in reply to: Haad_Ali
This is what I suspect at first, so I subscribe to their service and try the cloud rendering. But it comes out the same as before....
g-andresen
please show your arrangement in a screencast
günther
TrippyLighting
@Haad_Ali the amount of geometry in a scene has a negligible effect on render speed.
Haad_Ali
in reply to: TrippyLighting
@TrippyLighting But i have observed that several time the less component we have in scene the more better results it gives in cloud rendering. But, if i increase the number of components then it gives weird results and even that more time. Its not just the one time experience i personally face that every time.
Technology Administrators
