- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Greetings all,
I regularly use Fusion's sheet metal tools, and perhaps I'm just missing something simple here, or maybe my workflow is just bad. Any insight would be invaluable to me.
My company has a CNC plasma table and semi CNC press brake in-house which I primarily operate (I'm also the only one engineering). When I create a drawing of my flat pattern and I'm adding bend center-line dimensions in order to set the machines back-gauge I'm having a bit of confusion when trying to create dimensions for parts with multiple bends. For many parts I must bump an edge, which has already been folded, to my back-gauge in order to perform the second bend. My issue is there does not appear to be a good way to get an accurate reference for the second bend center-line in relation to the outside edge created from the first bend (at least working off of the flat pattern).
In the first image here I will be bending 2 first, then 3, and lastly 1. This order of operations is critical due to tooling limitations. The dimension from outside bend line on bend 3 to the center of bend 1 is shown as 2.013in, but if I unfold the same part in the design workspace and pull a measurement via a sketch from the center of bend 1 to the edge of bend 3 the dimension shows as 1.869. There's no way to unfold a sheet metal part partially in the drawing workspace in order to dimension the part in the way I am intending (almost showing the bending process in stages, 1, 2,3, ect.).
When actually performing the bends in the press brake I have found that the part comes out correctly using the dimension I have pulled in the design workspace, not the one referenced off of the outer bend line on the flat pattern. This is incredibly annoying because for documentation purposes it means I have to hop between work-spaces and manually change the dimension shown on the sheet to what I've measured off of the model. It's obviously even more annoying when the part has more bends and details.
Is there a simpler way? Or am I perhaps doing something wrong on the sheet metal rule end? I've painstakingly made test bends with multiple sets of tooling to generate a sheet metal rule library for different material thicknesses, die combinations, and material types in order to get the results I want, I just wish the drawing side had a bit more to offer for manipulating sheet metal parts.
