Increase wall thickness
navpat
navpat
Hi all,
I've attached my fusion file. I'd like to know, how can I increase the wall size? I don't want to scale it.
Its currently at 6 something mm. I want to make it 10 mm. While! Keeping the inner diameter the same.
Thanks!
jhackney1972
Take the wall thickness measure and place it on your clipboard.  Use the Offset Face command and pick the outside face and enter 10-6.682 mm(your clipboard) as the offset.  Model attached.
John Hackney, Retired
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
TheCADWhisperer
@navpat
I think there is a much much easier way, but how will you manufacture something to Ø44.72135955?
