Increase light level in Design editor?
Is there a way to increase the light level in the normal "Design" editor so colors render correctly? My parts are set to pure white or very close, yet the editor always displays them as almost a dark grey. This happens regardless of material, but I normally have ABS or Polypro selected. In a similar way, it's almost impossible to work with darker parts because they render near black. Solidworks did this as well, but there is a way to edit the environment to push up the lux light level. Can't find options to change this in Fusion.
This isn't a problem with monitor brightness. Everything else is fine, bright whites, etc, it's just the way Fusion renders things for some reason.
Thanks.
