Hi. I have created a hollow casting pattern by modeling a solid and shelling the back to leave 1/4" of material. Several of the outside surface corners are filleted, causing the inside surfaces created by the shell operation to be filleted as well with a radius 1/4" less than the outer surface.
The model looks fine mechanically; however, some of the resulting back side radii are 1/8" and require a 1/4" ball end mill to cut down to those surfaces. At its deepest point, the hollowed out back is 2.25" below the back plane. In other words, to reach the deepest surfaces with the 1/4" ball end mill, the tool must have at last 2.25" of stickout below the toolholder. This is fairly skinny for a 1/4" cutter at 9X the tool diameter.
My model includes 2° of draft angle on all the "vertical" surfaces (i.e., normal to the back face). I have found 3° patternmaker's tapered ball end cutters, but I'm not seeing 2° tools.
Is there a straightforward method to increase the inner radius of fillet surfaces created as the result of a shell without modifying the shell thickness or otherwise changing the outside surface radius prior to shelling?
