Cut and extend...
Cut and extend...
benfishr
Cut and extend...
benfishr
I have a question, I import a .STL file into fusion 360 and convert it to BRAP. Now usually I start deleting triangles to get a solid model. For some reason it comes up with errors. I want to construct a construction plane and cut to make two sections so that I can extrude that to a particular length. Can anyone help me with this?
etfrench
Try it without deleting the triangles which cause a failure.  The triangular faces only affect the appearance in Fusion 360.  Printing or milling won't show them (unless they're on different planes).
ETFrench
SaeedHamza
Don't delete the triangles, merge them instead in the Patch environment
Saeed Hamza
TrippyLighting
Please share your design. The responses so far make a number of assumptions that may or may not apply to the .stl you are using.
benfishr
It's a piece from Thingiverse for a SD card holder but the holder is too small. I need to make the slot wider and the bottom slot higher. https://www.thingiverse.com/thing:2180452 Any help will be appreciated
etfrench
@jeff_strater: The BRep of this model doesn't seem to be able to be split.  Merge faces is also failing in the Patch workspace.
Note: Other converted BReps can be split.
@benfishr: At this point you would probably be further ahead to just recreate this in Fusion 360.
ETFrench
HughesTooling
The mesh is pretty bad, lots of overlapping triangles and internal meshes where the part was modeled badly. Shows what a toy 123D is compared to Fusion. I fixed the worst parts in Rhino, imported to Fusion and converted to a BRep. I made one surface transparent so you can see some of the internal meshes that shouldn't be there.
Here you can see some of the overlapping faces on the base I had to remove also the curved area on the inside had 2 meshes one on top of the other. Fusion File attached.
Mark Hughes
Owner, Hughes Tooling
