incorrect system time error
I Just downloaded Fusion 360 - When I open Fusion 360, I get an Incorrect System Time Error and it will not open.
whats the fix?
innovatenate
Autodesk Support
Autodesk Support
The time and date stamp must match your current time zone exactly. If you are off even a few seconds you may get this warning. The best thing to do is reset the clock to the exact internet time.  Are you running Windows or Mac OS?
Nathan Chandler
Principal Specialist
Hello Buttabill, I have the same problem in the past.
You can check this pdf file: https://forums.autodesk.com/autodesk/attachments/autodesk/124/27224/1/Incorrect%20Time%20at%20startu...
Hope this solve your problem!
By the way, can you help me with "Like" button for the posts below?:
1. https://fusion360.autodesk.com/projects/kujang
2. https://fusion360.autodesk.com/projects/akik-indonesian-gemstone
3. https://fusion360.autodesk.com/projects/delman-style-lounge-chair
I am participating in autodesk fusion 360 competition in Indonesia. Thank you very much!
Best Regards,
Arif
