Inconsistent angle dimensioning with configurations
Hello, I am modelling a tank that needs to have 6 configurations.
The differences in the configurations are the angles from datum, at which 3 pipes exit the tank.
These angles are defined as editable properties in the configuration window which are referenced by a sketch which is used to create planes in which orientate the pipes.
My problem is that sometimes these angles are clockwise from datum and sometimes these angles are anti-clockwise from datum, sometimes they are 180 degrees out. In the attached archive file the sketch in question is called "angles".
My question is, "Is there a method by which angles can by defined as clockwise or anti-clockwise and restricted so that the affected line does not flip through 180 degrees that is still configurable?"
