Inappropriate labels in Modify>Scale dialog
nnikbin
nnikbin
Selecting Non Uniform scale type in Model and Patch scale dialog shows parameters labeled "Distance". I think the labels should be "Scale Factor" (X Scale Factor, Y Scale Factor, Z Scale Factor) instead of "Distanse".
I think the programmer has borrowed this part of the Scale Command's code from "Move Command"!
In contrast, Uniform scale type uses "Scale Factor" label.
The following picture shows both dialog boxes for Non Uniform and Uniform scales
Navid
jeff_strater
Good catch!  Thanks, @nnikbin, for reporting this.  I'll file it.
Classic copy/paste mistake by a software engineer!
[edit] filed as FUS-28524
Jeff
Jeff Strater
Engineering Director
nnikbin
Thanks Jeff for logging it.
I think the documentation should also be edited.
Here is a screen capture from the help file:
