Inactive parts barely visible
I'm new to f360 and am attempting to create an assembly hat has multiple components.  However after creating the first component and then activate the next component, I can only see the first component very lightly.  If I don't look hard I don't see it.  Is there a way to change the transparency level of inactive component, the component color, or the screen background so that I can see and use these inactive components as references?
Marco.Takx
Hi @Anonymous,
I think you are looking for the Opacity Control.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
jeff_strater
You can disable the dimming of non-active components by unchecking the "Active Component Visibility" setting in the Preferences, on the Design tab:
There is no way to control the amount of transparency if this item is checked
Jeff Strater
Engineering Director
Jeff....Thanks for the response. This does exactly what you say, but doesn't resolve my problem. I tried another response that I received and neither worked. I dug out an old Win 7 machine that had a different graphics card and the problem doesn't exist there. So it appears to be a hardware issue rather then a software setting. I'm going to go down that route and swap out the graphics card to see if that makes a difference. Again, thanks for the assist.
Marco...Thanks for the response. I tried adjusting the opacity but that did not effect the non-active components.  I then tried another response that I received and neither of theses suggestions worked. I dug out an old Win 7 machine that had a different graphics card and the problem doesn't exist there. So it appears to be a hardware issue rather then a software setting. I'm going to go down that route and swap out the graphics card to see if that makes a difference. Again, thanks for the assist.
Marco.Takx
Hi @Anonymous,
Thanks for your feedback.
Before switching the Graphic Card try first another driver to see if that fixed the problem.
Marco Takx
