In what manner does Fusion support color information in exported STL files?
personflakes
Observer Observer
personflakes
Observer
Observer
I maintain an STL decoder, and have been trying to hunt down files representing edge cases and nonstandard features.  I am not a Fusion user, and I have no access to it.
I have run into a handful of STL files which were ostensibly made by Fusion 360.  These are binary STL files, and they have 'COLOR=' tags in the file header along with an embedded uint8 RGBA tuple.  This appears similar to the format used by Materialise Magics for encoding per-object color.  I want to know whether Fusion also supports the same 'MATERIAL= ' header tags that MM uses, or whether Fusion also supports per-facet color information in the same manner (if at all).  I have not found any examples, but it's essentially impossible to search the web for such a thing.
Is this behavior publicly documented anywhere?  Does anyone have an example STL which demonstrates either per-facet color or per-object material (reflectance) information?
The complete impossibility of web searches suggests that I must clarify:  This is not about trying to bludgeon STL into a multicolor 3D printing workflow.  This is a question about nonstandard features of the file encoder.
TrippyLighting
I have reposted this on the EE Slack channel where we (Expert Elites) have direct access to the Fusion team.
I provided a link to this thread. With a little luck we'll get some feedback here. It might take a while though!
personflakes
Observer
Observer
Thank you for the connection.  I'm not exactly in a hurry.
personflakes
Observer
Observer
Any updates on the crosspost?
TrippyLighting
I've got some replies, but noting conclusive yet.
Usually .stl does not support colors, so I guess the question is why the exported .stl include these tags included, even if they aren't used. Someone answered:
"Years ago we added non standard  color  attributes to bodies in inventor. This seems to have made its way into atf. I know it used to be true that fusion did not export color and inventor users asked us to add it. This could be how the current support came to beIf I remember correctly multiple other CAD apps do this as well."
I don't know what "ATF" is and have asked for more feedback ...
personflakes
Observer
Observer
I'm not sure what it stands for, but it's part of the header text. For example:
'STLB ATF 12.14.0.127 COLOR=õõöÿ'
Seems to be
STL (binary)
Encoder or library abbreviation and version number?
Object color = [245 245 246 255]
Not sure if the encoder ever puts these header tags in an exported ascii STL (or whether it can export ascii STL) ...
