In sketcher, ow to tell which coincident point is fixed
Noah_Katz
Message 1 of 9
Noah_Katz
I wasted enough time trying to figure out what geometry wasn't completely constrained in a sketch, so I fixed a point which is the centerpoint of several circles and arcs.
Now I want to change a dimension and can't because of the fixed point.
I tried setting the selection filter to geometry constraints, boxing in the points, and "delete" but that didn't work.
Replies (8)
Message 2 of 9
davebYYPCU
Use Select Other, when presented with the list, you select each entity in that list, (keeping the list active) and the associated geometry will highlight.
in my cases, selecting sketch point, will show which circle is associated, test the list to find the right one and actually select it, by leaving the list.
Might help...
Message 3 of 9
Noah_Katz
Select Other shows 6 points, 2 curves, and 3 dimensions.
When I hover the cursor over the points in the list, the point turns white, and when I hover over the curves and dimensions, the green dot for Fixed returns.
So not sure what to do with that.
Message 4 of 9
davebYYPCU
Six minus five equals one.
Until the green dot changes colour you have not found it.
When you select point, that does change from green, hit the unfix constraint, no more green points, should be right to go.
Message 5 of 9
Noah_Katz
None of the points did that
Anyway, I kept deleting curves until the green dot went away, telling me which one's center point was fixed, did "undo" to get them all back, deleted the offending one, changed the dimension, and re-constructed the curve.
Message 6 of 9
davebYYPCU
Job done  - plenty of ways to skin the cat.
Message 7 of 9
Noah_Katz
Dang it - every time I get a notification I see "Status changed to: Solution Provided", only to be disappointed yet again 🙂
Message 8 of 9
etfrench
I'm not having any trouble changing dimensions on circles and arcs with a common point which is fixed.  Do you have other points constrained or fixed on the geometry?
You can unfix the point by window selecting it, Fix/Unfix, then repeat the selection and Fix/Unfix command.  The first Fix/Unfix will Fix all of the points selected, the second will Unfix all of the points selected.
ETFrench
Message 9 of 9
Noah_Katz
oops, sorry, wrong thread on the previous post
? Nor am I; that's not the problem
Ah, I didn't try that because I assumed that would just toggle all points to the opposite state.
That worked, thanks!
