Improving the display of icons within the software
lironxm
lironxm
Community Visitor
Community Visitor
Hi everyone, I did my best to improve the resolution of the icons, everything is pixelated, I'm at a loss.
See attached image.
I use a 14-inch Asus Zenbook laptop.
Thanks!
CGBenner
@lironxm
Hello and welcome to the forums!
Can you tell us what your screen resolution is set to?
Chris Benner
stiller.design
I also have often problems with the Icons and IU panels using a 4K monitor
TrippyLighting
@stiller.design @lironxm This is not a general problem every user encounters so the hardware specs. and software environment of your computers are needed.
Can you start by posting the graphics diagnostics of your machines?
Below is mine. My 2017 15" MacBook Pro is attached to a Blackmagic eGPU through Thunderbolt and is connected to a 4k LGCX 48" OLED TV through an HDMI cable.
I run Fusion 360 mostly through macOS but sometimes also through Windows 1o (Bootcamp) and in both environments, I do not encounter any graphics problems. That is not to dismiss your situation, but just to explain that this isn't a general problem everyone has to deal with
