Impossible joint relationship?
andy_woodward66
andy_woodward66
I'm trying to get this motion joint combination to work and it's giving me a headache. I've tried cylindrical, and I've tried revolute + slider with a motion link, but I can't get it to work.
Basically I want the screw to rotate radially but remain axially static, and the nut to move axially along the thread, but remain radially static. Obviously, the nut needs to move in accordance with the thread pitch.
Any ideas how to resolve this?
Replies (16)
TheCADWhisperer
@andy_woodward66
davebYYPCU
Revolve the Bolt on File Origin.
Cylindrical Joint on the axis of the Nut to File Origin.
Motion link, 360 degrees equal to pitch in the Slider part of the Cylindrical Joint,
and 360 : minus 360 degrees on the Revolute part of the Cylindrical Joint,
(there is a drop-down box for cylindrical settings in the Dialogue)
Might help...
It will only export as a .f3z as it contains imported components.
I'll create a new file...
andy_woodward66
See attached.
@andy_woodward66
Thread does not exit the Chamfer - Nut will never go on like this.
Drag the Chamfer feature to occur after the Thread feature...
andy_woodward66
Pedant. Have a try at answering the original question - which has nothing to do with an effing chamfer in the example file.
attached using a motion link as suggested by @davebYYPCU .
@laughingcreek
@andy_woodward66
Examine the Attached...
Thanks for the suggestion.
Unfortunately, I can't view this as a solution because you've added a component which wouldn't work in the target application.
I wanted to understand whether the motion could be realized using standard Fusion joints - I guess not!
Worked for me.
@andy_woodward66
How, oh tell me how, do you get it to work in the real world without an additional component (or two)?
Logic.
How so? I looked at your solution posted by @laughingcreek and it didn't satisfy the design criteria.
Same as my first reply.  I did not save the file, so have modified Alex's attempt.
Double check that the nut is travelling the right direction.
Position so you can click drag the bolthead and rotate to see continuous motion.
Might help....
Inertia. The radial stasis of the 'nut' component is a simulation of it's mass vs the diameter and friction coefficient of the 'screw'.
In the target application, the 'nut' is a relatively high mass circular steel plate. It's not just theory, it works in practice.
Brilliant. The nut is traveling in the opposite direction but I'll take a look at that in the morning.
Many thanks.
Put a minus sign in the value field, to reverse direction.  Yeah sorry about that, was the end of a long night, and Alex’s file put up a fight.
For some reason, Fusion did not need the minus sign for rotations, in Alex’s file, compared to mine and would be due to the Joint directions when created.
Might help….
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
