Importing .x_t file - convert to solid surfaces
cmcnc
cmcnc
I have .x_t files I've uploaded into Fusion (they are 3D scans). I'm trying to understand how to convert to create a solid surface so I can thicken it or add/modify to the exact part. I've been though a number of tutorials detailing meshing, stitching, converting as well as CAD Exchange to convert the file to a different type (.stp etc. etc.).
In theory getting this converted to a quad mesh seems to be what I need to do, though needing ReCap seems to be what I need.
I need the part(s) to stay exact as I need to model off these parts to add thickness, or add on components to the real part.
Any thought or sugegstions?
Charles
jeff_strater
it looks like it already is a surface body, so you should be able just thicken it from the Patch workspace.  If you want to share the file here, someone will no doubt try it out.
Jeff Strater
Engineering Director
cmcnc
Hi Jeff,
Thanks for the reply. I though the same as well, but thickening it in either model or patch mode does not want to work.
As suggested, here is a link; https://a360.co/2oKQtzz
Charles
jeff_strater
I was able to thicken this to 1 mm?  Are you looking to do more than that?
You can see, if you turn on a curvature map, you can see that this surface is pretty messy:
with lots of areas of high curvature, which  is why thicken is slow and may fail on larger offsets.
Jeff Strater
TrippyLighting
I would not call that "high curvature". Those surfaces are total garbage!
