Importing SVG not working properly, ellipsoids are not imported well
Message 1 of 9
Hei Guys,
I got a Problem importing SVGs from Inkscape to Fusion.
Best way to tell you what's worng should be two screenshots.
The Ellipsoids are totaly damaged after importing.
I don't know what's wrong with the svg.
When you look at the grape, you see that the leaves are imported properly
Hope anyone can help.
Manuel
Replies (8)
Message 2 of 9
g-andresen
are you sure that the imports are vectors?
Please share SVG und f3d from imported file
günther
Message 3 of 9
Here is the SVG,
I designed everything in Inkscape so in my Opinion these should be kind of vectors.
Message 4 of 9
HughesTooling
Imports correctly into Rhino so looks like a Fusion problem. @jeff_strater  Can you take a look.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 9
HughesTooling
@Anonymous  Attached is an f3d file created from exporting your file as a DXF from Rhino. The scale will probably be wrong but scaling to the correct size should be easy enough.
Mark
Mark Hughes
Message 6 of 9
Thank you for this Quick fix,
unfortunately I got a lot of SVGs with this issues.
So should i convert this to dxf before importing ?
Message 7 of 9
HughesTooling
Well until Autodesk get it fixed using DXF should work. Does Inkscape have a DXF option or will you need to use another program? Rhino does quite a good job reading the SVG and exporting to DXF but some programs have problem writing clean splines to DXF.
Mark
Mark Hughes
Message 8 of 9
g-andresen
if you work in Inkscape you should:
1. remove the fills and save only the contours in the SVG
2. before saving you should do a conversion from contour to path. That way you will get a double contour, but it can be removed.
günther
Message 9 of 9
jeff_strater
bug logged as FUS-74290.  Thanks for reporting it.
Jeff Strater
Engineering Director
