Importing Inventor assembly with subfolder links
etfrench
Mentor Mentor
etfrench
What is the workflow for importing Inventor assemblies/files which have links to assemblies/files in a subfolder?
ETFrench
etfrench
The Inventor assembly used the Design Accelerator (whatever that is Smiley Happy)
ETFrench
James.Youmatz
Autodesk Support
Autodesk Support
Hi @etfrench,
I'll have to check in with our Inventor team regarding what Design Accelerator is, but traditionally the best way I know of using Inventor Assemblies in Fusion is to use the Pack n Go command to zip up all the referenced files into a zip file. Then, in A360 or Fusion (I typically use A360 if the Pack n Go is huge) and upload as an assembly, selecting the correct parent .iam file.
If you want, I can try this workflow with your Pack n Go? @paul.clauss has a good screencast demo'ing this workflow here.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
etfrench
I don't have Inventor, so I can't change the assembly.  I was able to upload the individual parts, but of course, this loses their relative positions.
The model is for a planetary gear drive from this website: https://0x7d.com/2014/41-gearbox-for-nema-17-stepper-motors/
ETFrench
James.Youmatz
Autodesk Support
Autodesk Support
Hi @etfrench,
I downloaded the ZIP from that website and I was able to get a bit farther - although the final assembly does not look like the picture. My workflow was:
  • Visit A360
  • Unzip the file from the website so it is just a folder
  • Navigate to the folder in A360 where you want to upload the assembly
  • Select Upload-> Assembly
  • Choose the .IAM that you want for the parent assembly
  • Go to Fusion, and find the .iam that is now uploaded
  • Right-click and create Fusion design
James Youmatz
