07:25 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When importing the dxf files, it reduces the scale of the object in the drawings. I've been doing a bit of research and it seems to be a common problem. How do you fix this issue within fusion, or is it a problem with the exporting software? We are using Drawing Board v1 to export, and all the units are set to our desired output, inches, and the ratio seems to be set right within that program. All 1:1. I can't seem to figure out the solution for this.
