Hello Fusion Experts,
Can't get Fusion 360 to import *.rsdoc (DesignSparks Mechanical) files.
It shows "processing" forever, but even a simply body does not get converted.
What do I wrong?
Thanks in advance for your support,
Paul L.
@Anonymous
It doesn't look like that is a supported file format, I could be wrong though.
Phil Procario Jr.
Owner, Laser & CNC Creations
Hi @Anonymous,
Thank you for your post in the Forum.
Yes, I do agree with @PhilProcarioJr.
Could you may check if you could export your design into *.step, *.iges, any other CAD format?
Please, keep us updated.
Hi.
Unfortunately, DesignSpark can't export to STEP, IGES, etc. Is one of the restrictions of the free version, you must pay to enable this capability. It's possible to export to STL for 3D printing and also to 3D pdf. In FreeCAD, it is possible to import the STL and convert to mesh and then to solid, but you will lose information and may be will not be useful to you.
Kind Regards.
