Importing components to a parametric design
natalevo79
natalevo79
How can I add a component to a parametric design, that is driven by drawings, and have that imported component attach to a design feature.
I have imported a castor into a design and trying to align it to its specific mounting holes.
The model then changes when the parameters are changed and I want the castor to move with the design and its specific location.
I have tried a few different ways but cant seem to make it move with the parameters.
I have included a snapshot of the yellow castor on the parametric frame and a second shot of the frame parametrically changed but the castor is in the same position.
How can I restrain the castor to the correct position so it will move with the parametric changes in the design?
jeff_strater
use Joints to position the caster relative to the frame, not Move Component or Align - those are not parametric, and will not update when the model is changed.  A Joint (not As-Built Joint) requires geometry selections on both components, and those will update with model changes.
Jeff Strater
Engineering Director
g-andresen
Create a joint via Assembly > joint to the desired position
günther
natalevo79
Thank you.
I was trying to do an as built joint to aid in the speed of design. Then when I tried to joint the component only the base plate of the castor stayed with the constrained position. I then tried to rigid group the castor, still didnt work. I ended up joining all the bodies so it will stay the desired position in this design, as the 4 components of the castor are not critical in relation to the design.
Is there a way to make the attachment easier or does the castor have to have all 4 components jointed to stay in position with the parametric move?
I imagine this would weigh down the processing of the model as it grows in size.
natalevo79
Thanks. It is a solution. I was trying to do it an easier way as the model is getting large and jointing appears to really slow down the processing.
g-andresen
please share the file for reply
File > export >save as f3d on local drive > attach to post
rightclick imported component (chain symbol) and break link temporarely
günther
jeff_strater
yes, you would have to create joints for all components in the design for it to be fully parametric.  If you use Rigid Joints, it should not slow down very much - Rigid relationships are pretty easy to solve.  It's when you use a lot of more complex relationships (ball joint, pin/slot, Tangent) that things might slow down.
Jeff Strater
