Importing a Custom Title Block Problem
marks3U6W9
marks3U6W9
I'm trying to import the following DWG custom title block into Fusion 360 and having no luck at all. Nothing appears when I try to import. Any assistance would be greatly appreciated. Thanks
andrew.de.leon
Hi @marks3U6W9,
Sorry you've had trouble with this. I took a look and there was 1 block in the drawing so this should have displayed a warning and prevented the insertion. And on a closer look, it was 25.4 times larger and 0,0 was somewhere far off the bottom right corner. So I exploded the block, scaled down by 0.xxx-xxxxxxxx, and move the bottom right corner of the border to 0,0 and it came straight in. So try the attached file and let me know if you're still having problems.
Just curious, in what product did you create your DWG file?
Andrew
MacBook Pro (15-inch 2017), macOS High Sierra (10.13), in Sydney Australia
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
marks3U6W9
Really appreciate it Andrew. I was using Autocad 16 for Mac but had downloaded a starting template and was modifying that one. To be honest I have almost no experience with Autocad so it was a bit of fumbling around in the dark. Cheers
andrew.de.leon
Hey @marks3U6W9,
No problems, glad I could help. FWIW, we have started work on our authoring environment. Its still early days so I can't say when it will be released, but once its released you'll be able to author your title block directly within Fusion. Here's a sneak peak. As we progress would you be interested in taking a closer look, maybe during one of our Office Hours calls?
Andrew
Andrew de Leon
marks3U6W9
Of course Andrew. Happy to be of help anytime. Just let me know. Cheers
