Hi everyone,
I've imported a SVG within a sketch. It's the first time that I'm having trouble with keeping the imported shape after adding constraints (2:46).
These are the steps I've done:
Inkscape
Create paths
Add a stroke
Convert path to object
export as SVG
Video starts:
Fusion360
New sketch
Insert SVG
Scale with factor 3.77953
Apply concentric constraints to two circles
construction lines:horizontal and vertical
Trying to constrain the "snake-like" shape:
construction lines: Horizontal line, vertical line
collinear constraint to horizontal construction line circles and "snake-like" shape
collinear constraint to vertical construction line circles and "snake-like" shape
"snake-like" shape distorts.
While trying to resolve this the first time I added tangent constraints between each part of the "snake-like" shape. Second try curvature constraint. Both distort the shape.
The goal is to have the outer circle concentric to a secodn circle, which is not shown in the recording. All of the sketch elements should move together.
Any suggestions? This thread doesn't seem to offer a solution.
Thank you in advance!
