Imported DXF sketch has lines on different planes.
It is faster for me to redraw these but I was specifically asked to see if there is a faster way to connect the lines arcs and radii.
looking at the sketch from the top (on a different plane view,) it looks that some of the lines are different planes.  (the files is only one sketch)
is there a way to "flatten" the sketch other than projecting onto another sketch than having to remove the projection constraints?
Any advise would be appreciated.
File is attached
removed
davebYYPCU
Yes there is a way to flatten a sketch like that, I presume you found it.
jeff_strater
in case not, here is a screencast.  Also showing how to repair the outer profile so that is is recognizable as a closed area
Jeff Strater
Engineering Director
