Import STL due to size/ Mesh to BREP to make Editable
I have to import an STL file to allow me to import the correct size into Fusion 360.  Trouble is, that if I import, I am no longer able to use Mesh to BRep which makes the STL editable.  If I open the stl, then I can use Mesh to BRep to make it editable, but the size will be 10X bigger.  Is there a way to do both, import the stl so I get the correct size AND THEN use Mesh to BRep to allow for editing afterwards  or vise versa?  Added screenshot for example.
I have to import an STL file to allow me to import the correct size into Fusion 360.  Trouble is, that if I import, I am no longer able to use Mesh to BRep which makes the STL editable.  If I open the stl, then I can use Mesh to BRep to make it editable, but the size will be 10X bigger.  Is there a way to do both, import the stl so I get the correct size AND THEN use Mesh to BRep to allow for editing afterwards?
TheCADWhisperer
Do you have Capture Design History turned off?
Omg that was it!  Once I turned off the capture history, the Mesh to BRep showed up as an option after importing!  Was banging my head against a wall for hours!  Thank you so much!
TheCADWhisperer
That will only result in headaches.
Most questions are answered here within minutes.
